CH18 build
Well, I have the boat interior filleted and glassed. I must say that the cockpit glass was a bit of a challenge...just keeping it from pulling up off the keel as I worked up the sides. Touch and go for awhile and almost went into panic mode there for a bit, but finally got it laid in and it turned out ok. Another interior coat of epoxy tomorrow and on to the next step. Perfect weather here in Southern Maryland for building right now as I am building the boat in the loft over the garage. It gets pretty hot up there when the sun is beating down on the roof, but that should work to my advantage as it gets cooler.
« Previous Post     List of Posts     Next Post »
