MC 16 - Hull fairing and footbrace question
I've got 3 coats of epoxy on the hull and most of the weave filled. I'm planning on a forth light coat. Once this is done, should I go ahead and do any fairing to the hull now or wait until the deck is finished? I am building the Hybrid version if that will make any difference.
Also, is there any way to install the footbraces without drilling thru the hull? I was thinking of gluing a strip in the cockpit and installing to it, but not sure if it will be strong enough.
I'm planning to mostly use the boat in a rowing form. Does the rowing wing have additional parts that must be installed early in the build or am I safe to wait until a later date?
Thanks John
5 replies:
RE: MC 16 - Hull fairing and footbrace question
As Laszlo said above use the mounting studs fro CLC.
Laszlo,
thanks. I'll get these.
I was looking through the forum and saw mention of using the micro-balloons in the weave. Iv'e got 3 coats on and filled the "low spots" last night which created some ugly sags and runs. Would it be best to sand them out and do a final coat with the cell-o-fill addative? If so, what ratio and best way to apply it.
Thanks John
If you have sags and runs, you could try scraping instead of sanding. Do you have a set of furniture scrapers?
Hi John...hope I'm not too late for your footbrace question. Here's how I did ours...4 years and still holding strong.
Rear brace:
http://www.flickr.com/photos/algonquinpaddler/469168090/
Front brace:
http://www.flickr.com/photos/algonquinpaddler/471884730/
» Submitted by Laszlo - Mon, 1/16/12 » 1:35 PM
John,
CLC sells footbrace mounting studs. There's no holes and they're stronger than drilling through. I've used them on 2 boats and am planning on using them on a third.
Click on the picture to see how to install them.
