I was test fitting my coaming yesterday and had questions.
With the noseblock in place, I ran the coaming along side of the carlins. The coamings wanted to flair out. When I clamped them into the noseblock, they came back straight (more vertical), however they only made contact with the bottom portion of the carlins. Should I plane the bottom of the carlins until I get full surface contact between the carlin and coaming. This is only happens in the forward 1/4 of the coaming. Thanks for any suggestions.
John
RE: MC 16 Coming installation
Chris,
Loved your Photos. I believe that will work for me. Also like trimming w/ router. Great boat !!
As far as the front footbraces, I've ordered the stud kit from clc. The way you mounted was what I was thinking of doing it.
thanks again
» Submitted by Chris J. - Tue, 1/24/12 » 7:04 PM
Hi John...Would a different clamping set-up assist with getting full contact between the carlin and the coaming while holding the coaming into the noseblock? This is the set-up we used and it really pulled things together nicely. Hope it helps.
http://www.flickr.com/photos/algonquinpaddler/1356348408/in/set-72157594510381189
