Very interested in Madness but also very concerned about going aground with it. Cruising the Chesapeake or west coast of Florida, shallow draft sailing is essential. Hitting a sand bar at 15 knots will likely cause catastrophic damage.
Any thought given to a shallow draft rudder or possibly even a segmented rudder that could be operated at a half depth?
5 replies:
RE: Madness appendages
Wow! I can't tell if that guy is upset or excited about John's post!
George K
Yes, that's true, with Tri's and Cats, you can have a kick-up rudder, and daggerboards can always be lifted.
I grew up crusing the Chesapeake in a Folkboat with a 4' draft. We ran aground all over the bay. Maybe just poor seamanship, but I would go to great lengths with the build to have the option to short cut over a bar or sneak into an anchorage under sail.
A Folkboat person!? Cool. Here's mine, a 1971 Marieholm, on the Chesapeake:
Currently stored behind the building at CLC. The poor thing donated its Harken self-tailers to the proa. Madness-the-proa started out as a design exercise: What could I do with PocketShip's pile of plywood, and the Folkboat's rig? (PocketShip and Madness are within a couple of pounds of the same rigged displacement.)
I sailed this one engineless all over the Chesapeake, running aground often. (Draft, 48".) Mine was much cosseted. It might be the best-handling displacement sailboat ever---not bad for a 1940's design.
John,
Completely agree on the Folkboat, ours was a Marieholm 76. It has spoiled me as every boat I've been on since couldn't measure up. Always in control no matter the conditions.
Working on a rudder design.
Mark
» Submitted by John, CLC - Sun, 1/29/12 » 8:55 PM
This question comes up a lot in proa circles. There's dissonance, though, because when is it ever normal for a 15-knot sailboat to be able hit things without being damaged? It's like asking a supersonic aircraft to double as a crop-duster. I just don't hear the trimaran and catamaran crowd talking about going 15 knots in 20 inches of water. (A Farrier F-24 draws 56" with the daggerboard down.)
Sailboats that can do an honest 15 knots---in trials so far, 15 knots is just loafing along for this boat---are as rare in the sailboat world as supersonic aircraft are rare in the sky. There are lots of 15+ knot sailboats with cruising accommodations and kick-up appendages, but they aren't Hobie Cats. They cannot hit something at high speed without at least minor damage.
As you would in a supersonic jet, you throttle up only once you are clear of traffic and obstacles. Like sandbars. Madness lives on the Chesapeake, and in a very shallow part of it at that. I've run aground 4 or 5 times in the few short months I've had the boat, and will run aground many times in the future. I was only going 6 knots or so (ONLY! My, how you change your frame of reference with multihulls). As planned, the result was that I lifted the offending board, got over the shoal, and moved on with zero damage. Hit a shoal in ANY 31-foot sailboat at 15 knots, and you're going to break something. They can't even engineer automobiles to survive 5mph impacts without damage.
I don't go to afterburners until I'm clear ahead for miles, with at least 43 inches of depth. Most sailboats on the Chesapeake have a fixed draft of more than 43 inches. You can do a lifetime of exploration on the Chesapeake in 43-inch+ water. When I need to get into thin water, as I do every single time I dock, I lift the boards and maneuver with the outboard, at a maximum draft of about 16"----the same that PocketShip draws with the board up. Coincidentally, PocketShip draws 43" with the board all of the way down!
