Where to place the stitch holes?
I am building a Shearwater 17 from plans and much to my dissatifaction there are no markings on the plans for the stitch holes. I have determined through other posts that they should be 4" apart and 3/8" in from the edge. I want to be as accurate as can be obviously....any advice on how others have accomplished this would be great!
RE: Where to place the stitch holes?
Cut a 3" or 4" stick as template and do a quick run down the edge.  Not a big deal.  Accuracy is not important here.
Kim
Kim's absolutely right about the accuracy. In fact, most plans show too many stitch holes. Unless the panels are exceptionally tortured, you actually get a fairer shape with fewer stitches. Fewer stitches let the wood curve more naturally and can avoid humps and bumps and twisting. On my current built I had the stitches no closer than 1 foot, but the average spacing was 4 feet (on an 18 foot boat).
So even if your design calls for 4" spacing (and by all means follow the designer's instructions), the exact positions won't matter.
Thanks again folks! I also sent an email to CLC and they confirmed what you are both saying...anywhere around 5" spacing is plenty and not to be overly worried about the accuracy of the holes. Seems like an extremely important detail but I guess I won't understand until I get there.
Harlan
This was the same issue I had. I contacted CLC and they sent me a layout to drill the holes myself.  This took some extra time but apparently the drilling issue has still not been solved at the shop level.
