So, I'm really nearing the end of my build and was out looking for a leash today. The board is a Kaholo 14, but all the leashes I can find locally max out at 9 feet. This would obviously allow me to stand about anywhere I want, but I don't want to pay $30 for a leash then decide it's too short. Any advice?
I notice many of the photos I see don't show people using leashes at all, but I got the impression from a surf shop clerk this morning that the Coast Guard will want to see me using a leash if I decide to paddle between islands here in N. Florida.
Chris
5 replies:
RE: Leashing the Kaholo?
Clever! So no real need to go longer than 10 feet, even for a 14 foot board?
Actually I don't have a clue how long a leash is supposed to be RE board lengt so 10' was a Wild A-- Guess. I wanted it long enough for the person could be clear of the board but short enoiugh so that it get in the way while on the board or drag over the side so I added bungee to collect the excess in a snaky way.
Aloha ctwiggs. Maybe this info will help. After 40 years of surfing in Hawaii you can expect to fall off either a sup or a surfboard or any tool such as this. If your leash is shorter than the equipment you are riding it will have a tendency to either hit you in the head or face when you surface from your fall. When your leash is a slight bit longer it has a tendency to keep the tool/equipment away from your face and you can have a little more time to block and always cover your face, head , when surfacing. We surf on everything and anything in my48 yrs of ocean fun. Spare no exspence when it comes to a good leash.... agreat surf leash can tow a injured buddy to shore, it can save you priceless hrs of work loosing it on a jagged rock line. I hope I helped.
Yes, William, you make good sense. I am going for a coiled leash so it will be long enough to do he job but still stay out of the way. After building the board from plans and building the paddle from common sense, I have no desire to build a leash.
Thanks for the help!
» Submitted by hokeyhydro - Wed, 3/21/12 » 8:35 PM
I made one for the Kaholo I built for my daughter. Couple #8 oval head screws w/finish washers thru a doubled over webstrap mounted at the tail, 4mm line long enough, and then I stretched a couple feet of 4mm bungee out and stitched it to the line. Result, bungee snaked the aft part of the line up so it wasn't dragging over the side or getting under foot. I seem to recall total extended length was around 10'. Works great - proven by actual test *splash down*. Oh yes, attachment to leg was a velcro strap I picked up at Wal Mart, pack of four for organizing lines for camping or boating.
