Some finishing questions and the obligatory epoxy ones too!
Hi Everyone!  I am working on a Shearwater 17 that has been in progress for going on 3 years.  This is what happens when you have 2 children and purchase a house right after getting a kit.  Well, we finally built a shop onto our house and the project is really back on track.  I have a hull and deck together, all is looking well at this point and I am just sanding in preparation for glassing the outside.
On to my questions.  First, I am concerned I am going to run out of the original epoxy which is now 3 years old.  I have an extra half gallon of resin, and I am getting new slow hardener (MAS by the way).  I am worried that if I run out of the original stuff after doing lets say just the hull, or even worse halfway through a hull or deck, what is the best way to assure an even color?  Should I mix the containers of resin that is left, and use only the new hardener? What carries the amber color? Looks to me like it is the hardener just from observation as my resin is still clear, but the hardener is yellowish.  Or... Just use the new stuff entierly?  I kinda like the amber hue actually.
Second, how ridiculous do I have to be about sanding before the glassing.  Specifically, when epoxy has stained the wood, but carries no wood flour or silica, will it just blend in when the whole boat is glassed? I am guessing you will never really get the wood back to its raw color anyway. So just remove any   drips, scratches and decreeable bumps and make it all smooth?
Finally, it seems the instructions don't tell you to glass the cockpit combing ply spacers on the outside of the boat, only wrap it to the inside.  Do you just make sure it is all coated in epoxy to protect the spacer from water? What about the edge of the rim itself on the outside? Cut it even? Same on the hatch openings, just glass up to the edge of the opening? Or do you have to fold the glass inside the hatch down to cover the spacers?
Sorry for the long post but I am just at that point of no return on a few steps and I just want to be sure! Can't wait to see this baby on the water!
10 replies:
RE: Some finishing questions and the obligatory epoxy ones too!
Quick change to my question, and a simplification as I think I have 2&3 figured out from talking to folks. But can you mix old and new hardener to make sure to have a consistent color?  My hardener I have now is quite amber and I think my plan is to mix a pint of new in with the old to see if that gets all my glassing done without changing colors halfway through the deck.  Thanks!
I'd suggest contacting MAS about the epoxy question - they can give you a definitive answer about mixing old and new or not, and if the old stuff is still OK. Their web site FAQs say that resing has an infinte shelf life and hardeners at least 1 year, but check with them directly (http://www.masepoxies.com/Content/Contact_Us.html)
Oh, I know the old stuff is good.  I have gotten the boat to this stage with it.  Fillets, interior epoxy etc.  I am just not wanting to risk a two tone deck hence the desire to mix the two to create  a consistent color.  Contacting MAS is a good idea.
Hi
I am at that stage with a shearwater. What are the answers to two and three?
For sanding questions see the 14 part CLC vid where they built a Chesapeak 16.  They explain it very well there.
But the quick answer is the time to pay attention to a perfect finish is before the glass is laid on.  Sanding is fun, sanding is fun, sanding is fun...
http://youtu.be/mPG6asQ82lQ  <<<The Video<<<
If you arn't to fanatic about how it looks and just want to get to the water, sanding to 120 will do fine.  I still have drips where the deck glass overlapped the hull and I was in a rush to get to the water.  I slapped several coats of varnish over it and went kayaking.
5 years later, scratches, dings etc.  Every time I launch people stop to tell me how great the boat looks.  Some day I may finally sand the drips out. I can not see that it effects the performance at all.
Someone said that "perfection is the enemy of good."
Just my opinion.  I truly admire boats with a fantastic finish.  It's just not for me.
Ed
if you're going to paddle around Manhattan, like Ed, Joey and I just did, a coffee table finish is not in your best interest.
Do the best you can and have fun!
Hey everyone!  Just thought I would give an update on my build and the questions that I had above.
1.  Epoxy age.  Didn't matter.  When I glassed  the boat the color matched perfectly.  I tested before I glassed by taking one of the deck forms that I had removed and glassed over it with half being done with the old and the other half new epoxy.  I couldn't tell where the line was where the two met at all and neither could anyone else.
2. Sanding.  Again I was worried about spots where epoxy had stained the boat and if it would leave tell tale spots.  Nope.  Blended in perfectly.  Sanded her smooth and glassed away.
3. Cockpit outer rim.  I was just confused on this one.  Glass on the inside, good large filet on the outside.  Looks fine and dandy.  I did come up with one trick though.  I flipped the boat upside down to do the filet around the cockpit rim to avoid any sagging or running on the deck.  Also I taped off the whole area to avoid any more sanding than I had to do.
I just finished my second coat of varnish and I am so happy to see her almost complete.  A few mistakes here and there that I will always notice, but for my first boat and learning a lot about wood, epoxy, glass etc I am very happy.
Here is a shot after the end pour.  Dang they look huge when propped up against a house!
end pour
Ooops.  Here it is.
Beautiful boat! Get used to hearing that everywhere you go.  Now get it in the water!  Dave
