Glassing the cockpit
I finished glassing the cockpit last night. It came out well. No bubbles or lifts. Althought I cam still see the weave of the glass in half of the cockpit. I realize that this is not the hull and doesn't have to be perfect. Should I go back over it with a thin layer of epoxy to elimanate the weave or is this just adding uneeded weight?
1 reply:
RE: Glassing the cockpit
It's better to not fill the weave inside the cockpit, as it just adds weight and makes it slippery. If you did fill the weave but still see it, wet it with water. If it disappears when wet, it will also disappear when varnished. -Wes
