Shearwater Sport Cockpit Forms
I'm working on the cockpit forms and things seem off. See the photos below. The forms do not fit the sides of the boat and the center form sits about 1/4" proud of the bulkhead and form 6. Not sure if I should shave down the center form so its flush. Also not sure if I should shape the sides of form 6 so it aligns with the shear clamps and side panels. Any suggestions?
I'm doing a Shearwater 14 hybrid next to it and everything on it fit just right.
RE: Shearwater Sport Cockpit Forms
I had the same problems on a hybrid sport. I used a strip to make sure the lines were fair, and had to push some of the forms down quite firmly. I'll post some pictures when I get back.
When I did my SW Sport Hybrid I moved the forms forward and back as needed to get a fair line on the deck, and had a good height in relationship to the shear clamp.
» Submitted by Chuck the Builder - Sat, 7/14/12 » 4:42 PM
Not sure why original photos did not load.![]()
