Painting a Hybrid's Hull
I'm considering painting my hull and re-varnishing the deck at the end of the season. Which should be done first? I have a pretty good idea of how I'm going to mask off for a small overlap of paint onto the deck. If I varnish first, will the paint adhere to the varnish? If I varnish first, will overlapping varnish look conspicuous on the paint?
5 replies:
RE: Painting a Hybrid's Hull
I did varnish then paint, as the varnish will show on the paint if you look closely. I masked just over the edge of the deck onto the hull. Remember to pull the masking tape off before the paint sets, so so don't get a step.
I solved this problem on my hybrid by covering the joint with 1/4" black marine vinyl tape. It still looks good after three years of hard use, and gives the boat a very professional finish.
I applaud you for wanting to paint the hull. Varnished plywood tends to look cheesy next to varnished cedar. A painted hull, on the other hand, tends to make the varnished deck look even better.
You can see photos of my boat, and the black stripe, at http://twofootartist.com/merganser-construction-notes/
-Wes
Yes, Wes, I have seen your Merganser Construction notes-that's where I got the idea! Odd: my first build was stitch-and-glue, and I thought all the plywood looked pretty nice. You're right-the cedar deck makes the plywood look "worse" than it does next to more plywood. I'm beginning to see why painting Hybrids' hulls is so popular.
And a varnished plywood hull can be stunning, especially if its finished with marine urethane, which is clearer and brighter than varnish. Check out my daughter's Ganymede at http://twofootartist.com/ganymede-construction-notes/
-Wes
I painted my hull because:
I didn't like the puzzle joint
I over sanded the hull into the darker plywood, looked blemished
And I've always always wanted to paint a boat...
I painted hull first because i figured I didn't mind if my varnish overlapped the paint slightly and as it turns out you can make great lines with painters tape
http://www.flickr.com/photos/greyskies/5913915202/
13 days
for Discount Code Savings!
Ranging from $30 - $250
