Is denatured alcohol the same as iisopropyl alcohol or where can you buy it?
RE: Denatured alcohol
So... can Bio-Solv be used anywhere that you would use acetone (ugh!) or alcohol?
Keith
I would avoid "rubbing alcohol" as it is isopropyl alcohol with water added.
Keith
I find that denatured alcohol evaporates faster than isopropyl, at least the concentration of isopropyl that is available in stores around here.
Denatured is available in the paint/varnish sections of hardware stores in the USA for about $15/gallon. I've heard that it's next to impossible to find in Canada at reasonable prices.
» Submitted by PocketShip - Sun, 10/21/12 » 6:50 PM
I wasn't sure...
http://en.wikipedia.org/wiki/Denatured_alcohol
http://en.wikipedia.org/wiki/Isopropyl_alcohol
CLC recommends denatuired alcohol...
http://www.clcboats.com/shoptips/finishing-tips/refinishing.html
http://www.clcboats.com/shoptips/finishing-tips/wooden-boat-maintenance-refinishing.html
but according to the below site, Isopropyl Alcohol works even better than denatured alcohol.
http://www.woodcentral.com/woodworking/forum/archives_turning.pl/bid/2105/md/read/id/88984/sbj/cleaning-up-epoxy-messes/
Krith
