I'm painting the hull of my WR 180 bringing the paint over onto the deck about 1". What is the best method of achieving a clean hard edge to the paint where it meets the varnished deck?
RE: painting clean lines
I get the impression that the brightsides paint will be fairly thick when built up with a few coats. Will the varnish for the deck build up to the same level or will there be a step down between the paint and varnish?
Scott
You should thin the Brightsides as per directions. You'll feel a very slight step with your fingertips.
» Submitted by Chris J. - Tue, 9/9/08 » 8:28 AM
