Just cut out the sheer panels on this boat. However I messed up on one of the scarfs in that the carf was sanded too thin amd broke away leaving a small deppression on the panel. What is the easiest/best method of filling the depression so I wont see the repair on the finished painted hull?
thanks
1 reply:
RE: millcreek 16
» Submitted by PocketShip - Sun, 11/25/12 » 2:29 PM
Could you get some thickened epoxy in there? It will fill the void and tie it all together. If anything is above the surface when it cures, use a scraper instead of sanding... or at least minimize sanding. Seeing as how you will be painting, it will be invisible when it's all done.
Keith
