First I want to thank those who have helped me and those that will help me here while building my Mill Creek 16.6.
Now about seats. This is a two place boat which will be used as a single quite a bite. I want to have the rear seat easily movable towards the center of the boat. I was thinking about wood rails on the floor with u-channel aluminum mounted on the seat so the channel straddles the rail with a couple of pins to hold it in place.
1. I weigh 200 pounds. Do you think the rails just epoxied to the bottom will be strong enough or should I use screws through the bottom to hold it?
2. How far back from the bow should the single position be located?
The seats back rest will rotate to horizontal so I can sit on that when fishing.
Thanks again,
Mike
1 reply:
RE: thanks and more questions
» Submitted by Laszlo - Wed, 11/28/12 » 12:23 PM
Epoxy is stronger than the wood in this case so screws are no advantage.
