Someone is advertising a Skerry for sale in the Bazaar and is offering it with an "invisible" trolling motor rig. I asked the person to describe it but I haven't heard from him/her. That said, I'm on the verge of completing my Skerry and now I'm curious about using a trolling motor on it, say on a quiet lake or pond. I can't imagine mounting a trolling motor on a double ender (though I seem to remember reading somewhere a long time ago that you could put one on a canoe) and I wonder if someone here knows anything about how it's done? Appreciate any feedback. Thanks, bob h
9 replies:
RE: Trolling motor for Skerry
A while ago, the old "Small Boat Journal" had an article on a rudder with a trolling motor built in.
Build a rudder. Take the trolling motor of your choice and cut off most of the shaft. being careful not to cut the wires. Use the motor as a template and cut the rudder to fit the motor. Seal the tube / wires with silicone calking. Run the wires up a slot in the rudder / tiller assembly and into the boat to the speed controller. Mount the motor to the rudder using epoxy. I need to send you a picture of this if my description is not clear. Now you have a boat gliding along with no visible means of propulsion.
I may do this myself, after my skerry is done building. (need to finish painting the interior)
John C-H (not to be confused with JCH of CLC Boats)
John, thanks for your reply to this. I think I understand it, but a picture is worth a thousand words. I'd really appreciate a picture if you have one. You could either post it here or email it to me privately; doesn't matter to me. All that said, the Skerry is such a terrific boat on its own merit and I will probably not tinker with it. The Skerry is my first boat building experience, so I guess I'll hust have to do another kit that will easily accept a trolling motor. Jimmy Skiff might work! Once again thanks, and pls send pics? Best, Bob H
John, I just realized, the only real change to the boat is the rudder, which means that one could simply have a second rudder, rigged with the trolling motor. Do I have that correct? Thanks. Bob H.
I've seen quite a few canoes with side-mounted electic trolling motors. There are also bow-mounted electric trolling motors commonly used by fisher-persons. I'd think either of those could probably be fairly easily adapted. Not invisible by a long shot:) But probably easy to remove and have out of the way when not in use.
Hi Bob,
That's right. I just thought of something. reverse wont work without the rudder blade locked in the down position. A nylon screw thru the swivel assembly would make a good shear pin to save the blade should it run aground. I'll try to get that picture on line tomorrow.
I had a canoe with motor mount. I still have the mount and thought of using it. I may give it a try. Actually, If I'm going fishing, I could row or motor. hmmm
Actually, fishing would be the only reason I'd use a trolling motor and I live on top of a nice bass pond which would make it ideal. Not that I'm against rowing but I've fished before in a small john boat with a trolling motor and it just makes things that much easier. I still may fool around with the rudder idea since all it would require is a second rudder. Look forward to any pics you can upload. Thanks John,
And Oqata, thanks for your comments too. I'd rather avoid the bow mount motor because I don't think it's fair to the Skerry to rig her that way. At least a hidden motor in the rudder gives her the natural appearance she deserves.
John, you can email it to me at [email protected]. I don't know how to upload a photo to the forum either. Thanks again. Bob
» Submitted by davep - Sun, 9/14/08 » 5:57 PM
As the Skerry has a pointy tail and it says 'invisible' I'm thinking they have built a well (think wide daggerboard case) somewhere aft?
