First time Stripper question
Due to work shop restrictions and weather I cannot do any fiberglassing untill spring. Because of this I want to get as much done in the winter months. My question is can I completely build the Cockpit before I do any fiberglasssing, including the Cockpit recess, Coaming Riser and the Coaming lip?
1 reply:
RE: First time Stripper question
If you are building a full stripper - not a hybrid - you could have months of work before you need to break out the epoxy. You might consider making the coaming riser and lip in your kitchen, where it's warm enough to use the epoxy. I'd wait on the recess, though. -Wes
