Staining Strips for Strip Planking
I can get Eastern Spruce locally for strip planking. WRC is scarce here. Has any one tried to stain strips? I could use mahogany but that is heavier than spruce. Any comments would be appreciated.
RE: Staining Strips for Strip Planking
Stain comes with several different vehicles. You can't use stains with an oil base. They will interfere with epoxy adhesion.
Staining wood is a ticky business, especially on softwoods. It's hard to get consistant results. And, if you ever have to make a repair that requires sandind the wood, it will be difficult to touch up the stain so the repair will not show.
» Submitted by Casey Wilkinson - Wed, 9/24/08 » 9:26 AM
You could stain the strips, but you will end up removing most or all of the stain when you fair the hull. Building a strip-built kayak requires even more sanding and some planing than a stitch and glue. You have to make several dozen or so flat surfaces into one smooth round surface. I would skip the stain unless you were to use it after fairing the hull/deck.
