Has anyone given thought to getting a flat flooring a NE.
Removable
RE: Camping with a NE Dory
I doubt I'll be camping in my dory but I do want to be able to take a medium size cooler and not have to put it in the middle compartments so I ordered a 2' by 4' piece of 9MM plywood to make a floorboard in the foreward compartment, providing a slightly larger flat area in that compartment. I also ordered some of the wood strips used in the dory to hold up the thwart seat boards. This new floorboard will sit on top of the mast step, and I will cut pieces to support the new decking around the outside.
It also will allow a person to step into the boat in that new flat area more easily.
John (CLC John) even commented that putting that floorboard there would allow a person to add more floatation underneath it in an area that would contribute to more floation if swamped. If you're not concerned about floatation, a person could use the area under the floorboard for storage with sleeved access ports, or hinge the deck board
Curt 830/997-8120
» Submitted by greg27 - Sun, 3/2/14 » 6:29 AM
im looking at the ne dory too, my thought is a 4 piece floorbard slotted for the first seat and cut to fit in the sterrn. fold it up out of the way when running drop it down and set up a 1 man tent on top
