Ran out of MAS epoxy so went to West Marine and picked up some West Epoxy and Slow Hardener. last coat of expoxy went on well and sanded out fine. I left the interior for three weeks while i put brghtsides on exterior.
Sanded and put on interlux schooner, came back a day later and varnish was tacky and blotchy. i assume this is blush. I've removed varnish with laquer thinner.
Im planning on washing interior with soap and water, letting it dry and then trying to varnish again.
recommendations? Shoukd i use schooner again or should i try z spar?
