Apps for kayaking, kayak-sailing, sailing
I've found some great apps for my iPhone I thought I'd mention here that can be a great thing to have on board. I'm interested in what others have in this regard. Here goes :
PREDICTWIND : wind forcaster and planner for even multi day trips. Probably my fav app.
WIND ALERT: a nice complimentary app to PREFICTWIND. Not as good but still fantastic and is good to have when considering a PW forecast.
MARINE TRAFFIC: this is an AWESOME app that gives real time position of every ship out there that's track able. Particularly good for monitoring commercial traffic.
CHARTS by EarthNC: the name is drab but the app is a brilliantly done mapping tool that can trace your plotted course on NOAA maps outdone only by:
BOAT TRACKER: uses sat imagery with a rainbow spectrum of color to calibrate speed in a quick visual that computes the color once the trip is over and max and minimum speeds can be arrived at for color coding. Its a blast to see your speed run in bright red and your slow pace in blue or turquoise. This is a fantastic app. Gives trip averages, etc etc.
BOUY DATA: my fav bouy app gives all the pertinent info you'd want most if the time. I like to have this to check the source other apps use to generate maps of trends and patterns. Again a great app.
Lastly: WHATKNOT- a simple but effective instructional app on making sailing related knots.
my most treasured top two apps are :
BOAT TRACKER and PREDICT WIND. MARINE TRAFFIC is next.
Pete
ps: it helps to have the add on battery pack for BOATTRACKER as it'll use too much battery and be dead in four hours if u don't. For a hundred bux or less u can double it - for another hundred u can triple .
5 replies:
RE: Apps for kayaking, kayak-sailing, sailing
Thanks for posting this. I do more sailing than kayaking, and I'm always on the look out for apps. I've used Predict Wind, and I agree with you. Eager to try out Boat Tracker. May need that supplemental power source if I like it a lot.
Dave
Ah yes the tide predictor - forgot to add that:
I use Tide Trac and Tide Data!!!
i prefer Tide Trac. Too I have a tide clock app as well.
How could I forget these!!!!!
Pete
Thanks for providing this. I'm too lazy to check--any of these ported over to Androids?
Yes you can get CHARTS by EarthNC for Android . Maybe Boat Tracker but factually I only kno of CHARTS. There are many many apps similar though to what I listed for tides that Android carries as well. On my Asus Tablet I have quite a few .
Pete
» Submitted by Laszlo - Wed, 6/19/13 » 1:00 PM
What, no tide predictor?
