Getting cured epoxy of bolt threads
I got sloppy with the bolts that mate the akas of the sailrig to the amas during some rework. Now all the threads are gunked up. What do u guys recommend to clear the threads of the copious epoxy?
thanks in advance.
Pete
6 replies:
RE: Getting cured epoxy of bolt threads
you can break it off with a pliers.
epoxy wont usually bond well to a bolt unless it was prepared to be bonded. just be careful not to strip the threads.
put a little wd40 on the nut after you are done and screw it onto the bolt. that should remove any remaining particles.
i have used this technique to clear c-clamps that i spilled epoxy on.
works pretty well.
Howard
If you can't get it off with the pliers, try applying heat to the bolts. Just don't over-do it!
Keith
Another possibility if pliers and heat don't do the job... try carefully turning a die onto the bolt to clean the threads. You could even apply heat and then try the die while it was still warm.
Keith
Ok I did the heat thing and it readily chipped and flaked off via heat gun treatment and a pocket knife. Tomorrow I'm using a wire wheel brush in a drill to get the rest out.
thanks guys!
Pete
Ok a wire wheel on a drill has the not threads shiny and
new.
thanks!
pete
RE: Getting cured epoxy OFF bolt threads
» Submitted by PeteProa - Sun, 8/11/13 » 3:59 PM
Thanks.
