Aw crud.
Was planning to cut out pieces for a Wood Duckling tomorrow and... I can't find the transom pattern. There's a medium-high to extremely-high possibility it went out with the shop trash. Crud.
Anyone out there willing to measure the base/length of this piece on their own boat and perhaps snap a picture (so I can simulate the curve)? With this info I think I can fudge it- I'd rather not buy another set of plans over my carelessness.
I'm open to other suggestions, too.
Thanks,
Patrick
RE: Aw crud.
Hi, Patrick:
I'm pretty sure I have a spare Duckling transom laying somewhere around my garage. (I didn't use it in the construction because I used it as a pattern for solid mahogany one instead.) I'll check tomorrow and let you know for sure, and if I have it I'll be glad to send it to you.
Jim
RE: Aw crud.
Okay, no pic will be forthcoming, but here's the best description I can give you. The top of the transom is 3 7/16" wide. It is 6 3/8" high. If you draw a line from the top corner to the bottom point the high point of the curve is 11/32" inside the line. It's made of 3mm and the grain runs across (side to side).
Hope this helps.
George K
RE: Aw crud.
Gentlemen,
Thank you both! Jim, I think George's measurements should suffice, but thank you for the offer.
Onward and upward!
Best,
Patrick
21 days
for Discount Code Savings!
Ranging from $30 - $250
