My 1st experience with fiberglassing this morning!
My Peeler inside bottom was already for the 1st coat of resin over the fiberglass cloth. The manual said to mix up 8 ounces of epoxy, which I did. I poured it on and had my roller ready but the roller picked up the cloth so I switched to the squeege. That worked fine but I ran out of epoxy right away. I'm new at this and thought maybe the 8oz would cover the whole thing,, not so. I called CLC quickly and they told me about mixing up several small epoxy batches. I think there should be a footnote in the manual about that.
It all worked and my wife got a chance to spread epoxy for the 1st time in her life while I kept mixing up fresh batches. ( In a fresh container each time ). It looks good and I will put on the 2nd coat tomorrow.
1 reply:
RE: My 1st experience with fiberglassing this morning!
» Submitted by SurferBill - Wed, 10/16/13 » 3:20 PM
Glad it worked out! I thought I told you about that! lol! I did the same thing and I have some experience! I think it took about 24 ounces! i made a note in my manual, they need to tweek the manual abit! So now you know to have a helper mixing while you spread for when you do the bottom and sides. The reason to only mix about 8 ounces at a time is so you dont waste as much and also it takes longer to mix a large batch which wont give you as much time before it goes off. fresh batches spread and absorb into the cloth better too. make sure you have a bunch of spreaders too. nothing worse than having a sticky squeegee!
