Constructing the SHEARWATER 17 hybrid...
I’m planning to build a hybrid Shearwater 17, with S&G hull and strip deck.
I have previously built a full S&G Shearwater, so have no qualms about that part of the process, BUT – would it be OK to use 3mm marine ply (Gaboon/ Oukume) on the sides of the hull, and 3.6mm (Pacific Maple) for the bottom.
I have the 3.6mm left over from an earlier build and it seems a pity to waste it. The 3mm Gaboon/ Oukume is somewhat lighter in weight but appears a little less stiff than the 3.6mm ply. Irrespective, the as-specified ‘glass/ epoxy layer(s) will be applied to the hull bottom and sides as per plans.
AND – any special tips or recommendations from others on construction of this fine-looking hybrid would be very much appreciated…
Lawrence Watson
Brisbane, Australia
