Anyone have a SUT-250 Trailex Trailer?
I am needing to know some dimensions on the SUT-250 trailer to make sure it will fit (semi assembled) into the back of my Honda Element.
The four dimensions I need are:
--Width outside of fenders (To make sure the 68" on the CLC website is correct)
--Width outside of tires (not accounting for fenders)
--Width outside of bearing caps (not accounting for tires)
--Length of wood bunks (Assume with the center tube removed this is the longest dimension?)
Wondering why I need this?
We tow the Element behind our motorhome. We are going to put the dory on top of the Element upside down and the partially assembled SUT-250 trailer inside the Element...then assemble it when we get to Maine next spring. Each piece of the 2-piece tongue should fit down the middle of the element betweeen the seats, and I'm hoping the rest of the trailer (Axle and bunk assembly) will fit upside down on the bunks with the axle running front to back. I have 64" behind the seats to the tailgate (thus the questions about width) and 42" in width (thus wanting the length of the bunk)...
Thanks!!
Curt
