Kaholo 12-6 Bottom Panel Issue
After getting about halfway through sticthing my board I realized I made an error and glued the stern bottom panel to the bow ones at an angle (build is from plans). The bow came out reasonably well but there is an overhang on one side of the stern and a gap on the other (see photo). My plan to fix it is to cut off the overhang and glue it into place where the gap is now. Does this seem like a reasonable fix?
[URL=http://s558.photobucket.com/user/firstlight10/media/8354622E-379F-49F0-A078-CE53EB74325E_zpsj4jkn7xf.jpg.html][IMG]http://i558.photobucket.com/albums/ss27/firstlight10/8354622E-379F-49F0-A078-CE53EB74325E_zpsj4jkn7xf.jpg[/IMG][/URL]
RE: Kaholo 12-6 Bottom Panel Issue
I was able to wire up the nose and it looks good, all holes lined up reasonably well. The overhang is about 2 inches on the stern tapering to flush about a foot aft of where the bow and stern panels join.
The plan is to paint the bottom and sides so it'll be relatively easy to hide the fill in piece(s).
Sean
I ended up doing what I was planning on. It worked OK, wasn't a perfect fit but I am happy with it. On this build I am not striving for perfection, just a decent looking usable boat thats ready to go by paddling season in New England.
» Submitted by Patrick N - Tue, 2/11/14 » 8:10 AM
It's hard for me to gauge just how far off things are, but I'm inclined to worry about the possible crooked nose.
I'd avoid removing material at all costs. The overhang on one side comes with an equal and opposite shortage on the other, and I worry that such changes could really distort the nose.
Why not try to wire the nose to the frame first, ensuring that it's straight relative to the rails. A little discrepancy in the aft end might be easier to absorb/hide. If you really need to turn back the hands of time, plenty of folks report success with separating epoxied parts using heat.
Good luck- the Kaholo is really fun!
Patrick
