Due to the seeminly never ending winter and my lack of a heated shop my build is going slower than I want it to. I finally got the hull and deck fiberglassed and looking at the bow I want to do something to reinforce it from rocks, etc. Anyone have any ideas that are relatievly easy to implement?
As far as finish goes I am doing a varnished hull and deck with painted sides.
RE: Kaholo Bow Reinforcement
Thanks Tim. I like the rubrail idea, I'll see what I can find at a local marine store. My initital plan was to do the whole hull in graphite but decided against it as I really like the look of wood. I figure if the hull ends up getting banged up it will only be a couple days work to strip the varnish and graphite the hull. I agree about the solid design, there was 250+ pounds of weight holding the deck to the hull while gluing it down and I did not notice any flexing of the hull.
» Submitted by Tim Broyer - Wed, 3/26/14 » 8:05 AM
I built a Kaholo last year and had the same thoughts but ultimately didn't add much re-enforcment other than an extra strip of glass. Now that I've used the board in both fresh and salt water I have contemplated putting a rub strip on the bow. It's the most scratched area on my board (but it still looks really good).
I was paddling in the inter-coastal on NC and dodged oyster beds (they are like groups of razor blades). They had me thinking I should have used graphite for the entire hull!
A rub strip on the bow and perhaps some on the fins. I'm more of an explorer and adventure paddler and not looking for weight reduction and racing. Plus I let all the kids and grown up kids use the board. So far, the board has held up well. The boards are designed pretty solid and don't need much re-enforcement in my opinion.
