My winter project
https://www.dropbox.com/sh/l7g3scc0h61m6ts/2pNuj3GIz1
From plans.
Regards,
Nick
Nova Scotia
5 replies:
RE: Finished Kaholo 14
The fins are shaped from the plans but I added the FCS tabs and placed them where the plans indicated - no they are not staggered but I just looked at the photos and I see what you mean - photo illusion.
The centre fin box is just that, a long fin box. The surfer in me went for the set-up, and I may surf it just for a laugh, but the only real use for the centre fin would be to use a single soft fin in shalllow or river water and really the spec fins dont draw much...
I took a look at your Kaholo build when I was doing research - nice job.
Nick
Really nice. I like the mods you made. How is the bungee secured to the deck? Did you build in leash holders for the anchors?
I also like your handle mod. I've always thought the center handle on my board is a weak area.
Nick,
Very nice. Is that the breather tube incorporated in the handle?
George K
Tim. George - Thanks
Tim you are correct the bungee and the painter are held with surfboard leash anchors. I planned ahead and put round discs of plywood (on the underside of the top panel before bonding the top skin down) in those spots and premarked the centres with a deep punch hole so that it would remain visable after sanding etc.
The centre handle is reinforced and then oversized drilled and filled with epoxy. I drilled for the screw and then used a heated (very hot) screw to tap the hole.
The other T handles make carrying in the wind (2 people) and sketchy launches easier.
George - Yes the breather tube is incorporated in the handle. I sinkifexed the tube into place in the final assembly. I am hopeful that the bend in the handle will be enough to keep it dry inside. If it fails I can seal up the hole in the deck and try another method.
With any luck it will be in the water this weekend.
Nick
» Submitted by Wood_Ogre - Thu, 5/1/14 » 1:53 AM
Are those fins staggered or is just my imagination ? How about in the middle is that a long fin box?
