Northeaster dory flotation panel dimensions
I forgot to make templates from the bulkheads for cutting the foamboard for the under-seat flotation. They are all nicely glued in place. Anybody have the dimensions of these as heights and offsets from a centerline? Otherwise it looks like I'm going to do some impromptu small craft surveying. Thanks,.
1 reply:
RE: Northeaster dory flotation panel dimensions
» Submitted by Moonchaser - Sat, 6/7/14 » 9:22 PM
I didnt think to make templates first either, but found making the dimensions pretty easy..something like this (example only)..width minus 1" at the top, width minus 1" at the bottom, and height minus 1/2", and measure off a center line and round the bottom corners...note that each side of each bulkhead should be measured if you want maximum possible floatation.
Curt 830/997-8120 [email protected]
