This is the second project that I have used system 3 cross-linked polyurethane paint, which i highly recommend. System 3 sells a tipping brush for use after using a roller to apply paint. When this brush is used it appears that the paint has been applied in a professional spray booth! Such a small item-such great result.
1 reply:
RE: system 3 poly paint
» Submitted by Meyer, Robert - Sun, 7/27/14 » 9:45 AM
I second this. I've had nothing but good luck with the System 3 Poly Paint. I have had a problem using an eyedropper to add hardner to the paint - seems I always run out of hardner before paint. It does take a few days for the paint to fully harden - but then it's very tough stff.
