Gluing a compass mount to a varnished deck
Hello all,
I'm thinking of building myself a compass mount following these directions - http://www.clcboats.com/shoptips/fitting_out/compass_mount.html
What I'm curious about is what kind of surface prep is necessary before gluing the mount to the deck? The deck right now is completely finished, meaning a nice glow from 7 or 8 coats of varnish. Can I epoxy straight onto the varnish?
I'm hoping I don't have to sand down to the glass/epoxy before gluing this up...
RE: Gluing a compass mount to a varnished deck
Put down tape around the area where you will put the mount. Trace the mount onto the tape, cut out the inside and sand, scratch etc the area inside, Glue mount, them remove tape, Will save time and protect the varnish you already have down.
my 2 cents
If the compass isn't real large, maybe try some industrial self adhesive velcro. Some of the really good velcro is very strong. Also, look into dulling the surface mounting spot and using one of the good 2-way tapes. Just some ideas, good luck.
Another way is to mount the compass in the same manner that I mounted a GPS. I screwed the GPS mount into a varnished wood piece with holes through it on the sides for the front bungies go through, and thus it is totally removeable. Mine matches my wood bow and stern carrying handles.
» Submitted by Laszlo - Tue, 9/23/14 » 12:45 PM
No.
You do.
