graphite bottom separation from non-graphite hull sides
I am about to fiberglass and epoxy the hull of my Shearwater hybid sport kayak. I only want the bottom of the kayak to be epoxied with graphite. How do I separate and keep the graphit epoxied bottom of the hull from the sides? Would appreciate any suggestions.
PJM
RE: graphite bottom separation from non-graphite hull sides
x2. Just be careful with the roller. The graphite is tough to remove, if you cross the line. Keep the denatured alchohol or white vinegar close by. Even then you might have to sand the residue off if you get carried away.
» Submitted by Laszlo - Thu, 10/9/14 » 5:12 PM
Fine line tape is your friend.
Buy it here and use it like this:
Have fun,
