Shearwater Sectional from Plans
Finally made some saw dust.
Looking forward to this build with my 13 year old daughter and 16 year old son. Photos available at https://shearwaterkayakbuild.shutterfly.com/
So far:
- First sheet of plans put on plywood and holes punched along lines. Used thumb tacks for first sheet, switching to an awl so holes are easier to spot.
- Brads tapped into holes.
- Flexible straight edge used to connect dots between lines.
- Plywood cut 2mm proud of lines with saber saw. I know a circ saw cuts straighter but we have the 2mm and the sabersaw is easier to handle.
We have 2 more sheets to cut than some butt joints to work on... Any tips are most welcome.
John
RE: Shearwater Sectional from Plans
Tracing Plans to wood using brads tapped into pinholes that were pushed through plan.
We have CLC T Shirts, dust masks, safety goggles - need a hair scrunchy though.
Switching to using an awl. We did first sheet of ply with thumb tack. Hard to use and the holes were oh so tiny.
» Submitted by jshaley - Wed, 4/8/15 » 12:49 PM
I will paste some photos here as well, no need to jump to the Shutterfly site.
[IMG]http://i60.tinypic.com/2m2jmhc.jpg[/IMG]
