Hello from Greece
I bought plans for a Pax 20, 2 years ago and i started to build it. I already build a North Bay. The problem with the North Bay was the numbness. I change positions, add pads, new sits and the only solution was to build a new, higher front deck, with about 28-30 cm front cocpit height. Could someone inform me about the same measurment for the Pax 20?
Thanassis
RE: pax 20 front cocpit height
Thanks Rob C. I believe i can increase the depth about 30-31 cm without changing much. Maybe using a wider kingplank or something.
» Submitted by greg27 - Wed, 8/26/15 » 5:58 AM
Had the pax for a few years and tried the north bay at a demo the north bay felt a lot more cramped,that being said the pax is far from roomy.
