I purchased a Harken Hoister a while ago and found that the "block and tackle" portion of it twisted up so tight that the hoister wouldn't work. I solved this by installing a "fin" between the block and tackle lines to prevent them from twisting. I now have another block and tackle to use as a hoist for my new Jeep top. It also twists as I raise the load. What is going on? I'm wondering if the rope in the system twists as it is used, thus causing the block and tackle to also twist. I must be missing something.
RE: Twisting Harken Hoister
Appreciate your response. I tried to attach a pic, but w/o any luck. Don't understand the procedure. I did not replace any lines on the Harken Hoister; the lines just twisted up. You must lucky to have two hoisters w/o any problems. I tried to e-mail pics to Haken, but the e-mail is refused. I guess I'll look for another "fin" to apply to my new device................thanks
» Submitted by hspira - Sun, 7/10/16 » 6:12 PM
would be great to see a picture. maybe we could see something that you don't see.
i have a harken hoister - two of them. and no problem and no fin required. so i am curious what is causing the rope to get a twisting force when it is being pulled.
the only thing that comes to mind - did you change out the line that comes with it that has no braid with a line that has a braid? certain types of line would rotate/twist when pulled over a pulley. for these pulleys you should be using a cored line with a woven jacket that does not impart a twist.
