The choice of Epoxy paint for ship dedicated or not?
Currently there are many types of epoxy paint, but I don't know how to use. Thanks to the high you experience, just to help me with.
Epoxy paint is two-component products are produced on the basis of Epoxy, polyamide curing, solvent and zinc powder; used to protect the paint and decorate the surface of the iron, steel, wood, cement ...
With special features like:
-Good Water Resistant;
-Good surface adhesion;
-Good chemical Resistant;
-Alkali Resistant very good;
-Bear and touch the big mechanical;
-High durability;
-Temperature Resistant up to 1200C should Epoxy paint used in the industry to ship on the river and the ship, the chemical industry, and the industry in General.
The type of Epoxy paint coating specialized ships:
* Anti rust zinc rich Epoxy Coating:
Is zinc-rich Epoxy corrosion coating type 2 components, produced on the basis of Epoxy, zinc powder, metal, solid Polyamide anti-freeze, solvents and additives, to satisfy the demand on the composition of the SSCP paint 20 level 2. In addition, this product has to meet ASTM D520 Type 2 zinc dust.
Used as a rust-resistant Primer in Epoxy paint system, for ships and steel structures in high corrosion environments or regularly inundated (fresh water, salt water, steam, chemicals). Special anti rust zinc rich Epoxy Coating does not burn when cut with the wind kicking up and welding.
* Rust resistant Epoxy zinc phosphate:
Is zinc-rich Epoxy corrosion coating type 2 components, produced on the basis of Epoxy Resins, powder phosphate zinc, polyamide cured substances, solvents and additives. Satisfy the demand on the composition of the SSCP paint 20 level 2. In addition, this product also meets ASTM D520 Type 2 zinc dust.
Used as a rust-resistant Primer in Epoxy paint system, for the boat and the steel structure.
* Rust resistant Epoxy Paint Orange:
Is zinc-rich Epoxy corrosion coating type 2 components, produced on the basis of Epoxy Resins, pigments, corrosion inhibitor agent polyamide, solvents and additives. Satisfy the demand on the composition of the SSCP paint 20 level 2.
Rust-resistant paint used in Epoxy coating system, or intermediate layer for the zinc-rich Epoxy coating systems to protect ships, boats and other steel structures.
Epoxy paint
Is the type of Epoxy paint coating components. Produced on the basis of Epoxy Resins, pigments, agent polymide, solvents and additives.
Used as decorative paint in Epoxy paint system, to decorate and protect for the boat and the steel structure.
1 reply:
RE: The choice of Epoxy paint for ship dedicated or not?
» Submitted by Laszlo - Fri, 7/7/17 » 12:24 PM
Your epoxy paints are for large commercial ships. They are not the kinds of paint used to paint the boats that people here build. We tend to use single and two part urethanes, not epoxies.
Are you looking for help to paint a small boat or a large ship?
