What is the stronger epoxy bond?
I want to epxoy a 8 x 8 inches pc of oakam plyood to the inside on my fibreglassed hull.
What is better, just glue with thickened epoxy to hull or glass the bottom of my plywood let dry ,then epoxy to hull?
1 reply:
RE: What is the stronger epoxy bond?
» Submitted by Laszlo - Wed, 9/6/17 » 7:25 AM
Skip the glass, it offers nothing inside a glued joint. Just paint the plywood with unthickened epoxy, give it a few minutes to let it soak into the wood, then apply thickened epoxy and go.
