Frozen epoxy
I inadvertantly left my epoxy kits at the cottage (in Canada) when I closed up for the season. Will the epoxy and hardener survive freezing over the winter?
RE: Frozen epoxy
   I left mine in my unheated and uninsulated garage in New Jersey over the winter, where it froze several times, and then used them just fine this summer.
I don't know if there is a difference between freezing cold from time to time and freezing continuously.  My guess is that if you shake the containers up a bit so they're mixed in case anything separated out, you'll be fine.
RE: Frozen epoxy
   Please please remember to do a test batch before you use any epoxy that might have been compromised. A test batch will show if it is still good and potentially save you a very messy cleanup of epoxy that has decided not to harden.
RE: Frozen epoxy
RE: Frozen epoxy
Epoxy doesn't separate when frozen, it crystallizes. No amount of mixing will dissolve the crystals back in. Instead, you need to dissolve the crystals by warming the epoxy. A hot water bath works nicely.
