Can I find CLC colors in smaller quantities than quarts? I want to touch up my LT17 built 7-8 years ago and no longer have the paint I used then. Thanks, Scott
RE: Paints in smaller amounts
CLC sells Interlux Brightsides. You could try getting directly in touch with Interlux Support and see if they sell sample sizes. I purchased some System 3 2-part LPU in 4-oz sample sizes some years ago and used them for touch-up and making custom colors.
Good luck,
interlux sells in units as small as a half pint....but only in limited colors. so if you happen to have that as your color you are in luck...a link for these is below (this is just indicative, most major suppliers will stock the half pints)
http://www.discountmarinesupplies.com/Interlux_Topside_Paints-Interlux_Brightside_Polyurethanes.html?gclid=EAIaIQobChMIwI6-qIa72QIVxEwNCh0Udw76EAQYAiABEgILHvD_BwE
but if you can't wait to hit the link...here are the four lucky colors!
» Submitted by CaptainSkully - Wed, 2/21/18 » 10:44 AM
I'm not aware of any marine grade paint that comes in anything less than quarts. You may have some luck finding a touch-up pen in a close color at an auto parts store.
