Well not really IN the rain but in a shed when it's precipitating profusely outside.
I have put 2 coats of International Pre-kote on the exterior hull of my MC16 over the weekend when it was beautiful and dry, now a front has moved in and we have constant rain and humidity of 64%.
I was going to sand and put on the first coat of brightside today but should I wait until the weather improves and the air dries out a bit? I heard that prekote stuff soaks up the moisture a bit?
Also, any tips on applying brightside? I intend to use the yellow foam rollers. I've read about tipping out bubbles with a foam brush - just how many of these bubbles can I expect? A handfull or a couple of hundred over the boat?
Steve
NZ
6 replies:
RE: Painting in the rain
Hally,
There's a 300-pixel width limit on pictures posted here to make them fit into the gratuitously narrow porthole that this web server software enforces. I don't understand why with my 1650 pixel wide screen I'm forced to look at a postage stamp, but until CLC changes to a more modern and user-friendly display we're stuck with it.
In the meantime, right click and "view image" will display the entire picture.
Good luck with the paint job,
Thanks for the info Laszlo,
The forum is a fantastic resource for us budding builders but does appear to be a bit antiquated. I too have a lot of wasted real estate on my 1920 wide iMac. Photo's enhance forums so much, it's a pity this particular one is so cumbersome to use. I remember they (CLC) 'updated' the forum about a year ago, maybe it's time for another update. I for one would really like to see a preview post and/or edit post function.
and back on topic... was going to paint today but work got in the way.
Cheers
Steve
Rain gone - paint on
Hi again,
Just thought I would post some MC16.5 paint shots. I am quite happy with the result. Thanks to Wordsmith and others for their tips. However I must say I didn't need to to do any tipping with foam brush as I didn't encounter any bubbles - maybe I was doing it wrong or the paint gods were smiling on me. I used the yellow foam rollers cut in half to apply all coats, and yes there were hundreds of tiny bubbles but within maybe half a minute to a minute they all disappeared and left a smooth surface, smooth enough for me anyway.
Next step is to flip her over and sand/varnish the deck, and then LAUNCH! It's only been a year.
Also, a big thanks to ChrisJ. Seeing the flickr build set of his Mill Creek was the inspiration for building mine (hope you don't mind me pinching your colour scheme - unless either of us crosses the equator there's no chance of being seen together :-)
» Submitted by Hally - Mon, 4/6/09 » 12:09 AM
Hey thanks for the tips Wordsmith - really appreciate it. Had a look at your craft too - well done, she's a beauty!
This is mine sanded and ready for the pre-kote. Will post some more shots in coming days, hopefully with a nice clean shiny blemish free paint job!
Cheers
Steve
p.s. Are there any other CLC builders down here in Oz or NZ?
