Hey folks,
I had always intended on adding spacered/scuppered inwales to my plans-built Passagemaker, but didn't take the time as I was in a hurry to finish it before moving to the USVI for six months. As it was, I was only able to take it sailing a handful of times before putting it up for long-term storage.
I'm thinking about adding spacered inwales when I get back, but there's a complication: I've already done a 1/4" round-over on the inside, which would cause a gap. I could either fill this gap with wood-flour epoxy or lower the spacered inwale by 1/4". Both of those options have aesthetic drawbacks, not to mention the hassle of trying to "sculpt" the epoxy.
I don't think it will matter, but I also covered the edge of the shear strake with the gunwale by creating a dado or lip (see pic below).
I've also painted the interior, so I'd probably sand that down to epoxy or wood.
Now that I've stated the challenges, I think I'll stick with it as it is, but it's an interesting prospect. Thoughts?
RE: Adding Spacered Inwales Later
Hey Captain, since you routed to cover the plywood, as I did, you could plane to the low interior edge of the round-over. This assumes there is enough material not to expose the plywood, You would not have right angles but that should not affect the function.
Barry
@spclark, that's a really interesting idea. I never would've thought about that. Hmmm... Might also add a shadow line for visual interest.
@bearnkar, I forgot to mention that the oarlock risers are already in place, so probably won't plane down the existing gunwales. Great idea though. If I was serious, I could just run it all down to the plywood edge and start from there. Interesting...
» Submitted by spclark - Wed, 1/30/19 » 7:57 AM
I’ll suggest dropping spacers to where round-over ends on gunwale inside face, round over inwale too & secure w/top flush w/gun’l. No reason I can think of why spacers must be top-flush w/ pieces on either side!
Kinda trick prospect for sanding though once assembled then epoxy-coated unless you’re just not so fussy as to overlook a bit of roughness!
