Looking a real clear varnish or marine poly
At the request of my daughter, the deck of her light pine stripped deck of the shearwater 16 I am building will be a bright pink rose color. ( Hull be bright white. )
I used a aniline dye powder with alchohol. Need sunglasse to look at it.
The test varnish with Interlux schooner does not look so bad but I would like a more clear coating on the deck.
Any ideas?
Will poylurethane be to brittle?
Anthony
0 replies:
