Painting Questions...
Had a hammer drop off a rack that took a decent sized chunk of veneer off on one side panel of my second duck (pre glass, but post deck attachment; filets were curing)... so I have decided to patch over with wood flour/epoxy and then go with paint on the sides. I am going to go with the graphite/epoxy coating on the bottom panels and then thinking dark blue interlux brightsides on the side up to the deck (still going bright on the deck of course)
My questions are...
1. Will I get enough coverage with 1 quart of interlux paint to do this? I'm having a hard time finding this information other then that I will need arround 3-4 thin coats.
2. Should I do a primer coat first? (after fiberglassing; using the standard kit issued MAS Slow cure-non blush epoxy)
3. I am debating about doing a paint over the deck line much like alot of the painted chesapeakes i've seen - but having a hard time picturing this in my mind for the deck of a duck. My worry is that it will look out of place over the areas where the shear clamps come to an end and sort of twist up to the saple deck. Any yay or nay suggestions?
Painting Questions: masking
I agree with Dusty's advice.  Also--in painting my wood Duck 12 I learned the hard way not just to tape-mask a sharp line at the edges, but also to tape a protective skirt made out of old newspapers over parts not immediately being painted.  There are tiny drips and splashes ejected from a brush or sloughing off the edge of a cup of paint no matter how careful you are, which can be very annoying when they land on varnish, or a painted surface of a different color. Here's what my Wood Duck looked like (from a safe distance) after it was painted. http://jockyellott.googlepages.com/home
RE: Painting Questions...
I agree that wrapping the paint over the deck line is not the way to go - probably why I couldn't quite picture it to begin with; however I like the rub rail or thin line idea as a transition to the deck.
Just to clarify... The graphite/epoxy mix is just going to be on the bottom panels and seperate from the painted side panels.
Rafaelo, thanks for the advice and the pictures - to tell the truth it took me a while to come to terms with the idea of painting... but your duck looks great so a big sigh of relief here.
