Hi,
I want to remove varnish from 10 yr old C16. Itried wet sanding but can't tell varnish surface from epoxy. I don't get a soapy mix as suggested, just a whiteish powdery water mix. Is there a varnish stripper and process I could use? I'm concerned with damaging the expoxy/glass layer.
Thanks,
Chris
RE: how to remove varnish?
Hi Bob,
I want new epoxy to bind to the old surface at the bow and stern areas. Otherwise I now think I should just add a few coats of captain’s varnish to the bottom panels. Since the surfaces are dry I think it wise to seal them before I put it in the water. Would you agree? Any helpful thoughts /suggestions will be appreciated.
I just bought the older kayak which sat under a tarp outside for perhaps 10 years. The bottom 2 panels have a lot of scratches and a few 2 to 3" circular areas without varnish with exposed glass weave. I mainly want to seal exposed fiberglass weave.
Also the fiberglass on stems in both ends, bow and stern, have been abraded off, exposing about a 3 inch strip of bare wood.
On review I think I should put on a few coats of Captain’s varnish except at the bow and stern areas which I’ll reglass with patches about 3” by 1” with epoxy. I would like to remove the varnish locally in these ends, so I can bond to epoxy.
Thanks Chris
Here is a way that Nick Shade did it on one of his s&g Petrel Plays....... https://www.youtube.com/watch?v=Jig_pGN3Yus
» Submitted by Bob Santore - Wed, 9/4/19 » 9:49 AM
Are you removing the old finish just to rejuvenate the look, or do you need to do something structural, i.e. have new epoxy bind to the old surface?
