Trimming Wood Duck 10 hybrid deck
I have the wood duck 10 hybrid deck permanently attached to the hull. Have not sanded or glassed it yet. Is it best to trim the deck at this point? What is the best way and with what tools? Thanks. Matt.
1 reply:
RE: Trimming Wood Duck 10 hybrid deck
» Submitted by hspira - Sat, 1/23/21 » 11:13 PM
Hi Matt,
i just want to confirm the step that you are at. first, i am assuming you have glassed the interior of the deck? and that it was taped to the hull?
if that's the case, then you simply use a sanding block with 60 to 80 grit sanspaper to 'trim it' to be flush with the hull (you want to try to not sand into the hull, but just to use it to 'trim' back any overhang) and round over the sheer line. you then would use a succession of 80, 100, 120 grit sandpaper on a ros sander to to smooth your deck cedar strips.
