I'm building the Millcreek 13. I'm installing the fillets on the interior. I'm thinking of finishing the interior cockpit, up through the final coats of varnish, before I put the deck on: I think this approach would be so much easier to finish for that portion of the boat. I know this is out of sequence re: the build process. Has anyone done this or does anyone have any comments re: this approach?
Appreciate your input
RE: Millcreek 13
I painted mine early in the build. Almost done now. Two things I'd mention
1- you will have to cut the tops of the hanging knees flush with the carlins in order to fit the coamings later on
2- if you plan on a sailing component or sailrig leave an approximate 8x8 inch square in the center right behind the forward bulk Unfinished in order to glue the mast step in later on.
Good luck with the build, PP
RE: Millcreek 13
» Submitted by hspira - Mon, 2/1/21 » 1:18 PM
while i have not done this with a millcreek, i have done similar activities with other kayaks.
to your point, there are things that are just easier to do with access. the important thing is to puzzle it through to make sure any part of that is a smart step vs one that you will regret.
the two things i consider:
if you have specific steps that you are considering switching the order on, it may be easier if you propose them for more directed feedback on your ideas. but it is fairly common that builders, as the build experience, will switch the order of some things around to suit their tastes and make the process easier.
