Cockpit paint for mill creek 16.5
To all,
what recommendations are there for inside the cockpit choice of paint.
bilge paint, nonskid, deck paint, epoxy garage floor paint? What are most people doing.
thanks
Andreas
RE: Cockpit paint for mill creek 16.5
I just used the polyurethane paint I used on the hull . Seems to worked fine after a year of use on a regular basis.
» Submitted by Grumpy - Fri, 3/5/21 » 3:24 PM
Varnish....... Or topside paint All that other stuff is overkill. However you can spray truck bed liner if you want. It's your boat. Just remember non-skid, bed liner, bottom paint is all more expensive and heavy.
