Enough Epoxy/Graphite on Rubstrip?
Just looking for advice about my rubstrips. I've put three coats of epoxy/graphite mix on them after sticking the fabric down with plain epoxy originally. I think they look pretty good, but I can still see some of the fabric weave. -- So I'm wondering if I have enough epoxy/graphite applied to them.
I'm going to try to attach some photos, but that hasn't always been easy for me, so bear with me.
Thanks,
Dave.
https://www.flickr.com/photos/192908249@N04/shares/Tw2Na7
RE: Enough Epoxy/Graphite on Rubstrip?
Hi Dave,
i looked at your pictures. yes, you need to add more graphite/epoxy in order to fill the weave.
like you, i will start my rubstrips pulling them tight and focusing on attaching and initial trimming. once i have that, i will then remask and come in with an almost mayonaise consistency graphite epoxy mixture (lots of graphite to epoxy). i will then spread it on top of the dynel with a mixing stick or little spreader that i will make. once it hardens, i then sand it smooth and all the weave is filled in one step.
hope that helps
Hi -- thanks for the advice. For sure I can add more epoxy/graphite. By the sound of what you are describing I didn't have enough graphite in the mix, mine was more of a thick mustard, but still runny.
I will have to remask, which is not a problem -- will it be a problem if I wait 36hrs between these last coats and a last thicker coat - or should I sand inbetween for adheision?
Also - you mention you sand the strip after the epoxy dries (before varnish) -- is it the varnish that then returns the "shine" to the black of the strip?
Thanks again,
Dave.
not a problem to wait 36 hours. you can rough it up with a scotch-brite pad if you want, but it's not necessary....there are enough surface irregularities (e.g., the weave) that it will bond just fine.
on the "shine" you mention, that's a personal/aesthetic perspective. i leave mine flat black which is how it will look after sanding. you can make it shine by varnishing over it or painting it with clear epoxy. fwiw, i avoid varnishing any part of a boat that i plan to repair/re-epoxy becuase epoxy won't bond properly to varnish. i put rubstrips in that category of "plan to repair". typically, at the end of the season, i will evaluate how the strip is holding up. if it got used a lot, i will retape them, and build the strip back up to be ready for the next season.
» Submitted by Polman, Dave - Sun, 5/2/21 » 3:07 PM
Not sure that other link worked... maybe this will?
https://www.dropbox.com/sh/u0840l7myvot6er/AAAx1HZgle3uPDkYgdepD-Q6a?dl=0
Dave.
