Bottom of cedar strip canoe lifting off the molds
I am building a Prospector Ranger 15, cedar strip canoe. After I finished stripping and removed all my clamps the center of the bottom on the middle 3-5 station molds has lifted off the molds about a 1/4" inch. Aesthetically it looks fine, but it now has slightly more rocker than the original design and the bottom is more rounded that it should be. I think there is a number of reason where I screwed up to make this happen, but my question is should I fiberglass it the way it is or should I try and pull the bottom down to be tight with the molds, as best as I can, before I fiberglass it? I’m worried about the tracking and stability of the finished product. Does anyone have any experience with this problem? Thanks in advance for any help.
RE: Bottom of cedar strip canoe lifting off the molds
hspira
Awesome thanks for the advise. If I was to clamp it back down and set a heater underneath it on the strong back do you think that would be enough heat to make any diffrence?
i don't think a space heater will get the job done.
i would go over the area with a heat gun that is getting the wood hot using the same technique that is used when you actually need to apply heat to get wood relaxed enough to take a bend it normally would not accept.
on my heat gun, this is going to be a setting around 200 degrees. i don't want to burn or toast the wood, but this is bringing it to a point that it is too hot to touch. you can practice on a scrap piece of cedar strip to see the effect i am talking about.
the link below has a good overview on using a heat to bend cedar strips:
https://laughingloon.com/shop.tips.html
» Submitted by hspira - Wed, 5/5/21 » 1:35 PM
Hi KY,
while i have not built the particular boat you are describing, i have built a number of cedar strip kayaks and can confirm that its pretty common that you can get some shape drift after you pull the staples out.
i don't think, based on my experience and talking to designers that the 1/4" pop is going to have any "observable-by-you" effect on the boats handling or characteristics.
that said, there are a couple things you can do to minimize drift:
i hope this was helpful.
