Bottom panels stick out from side panels in stern on Chesapeake 17
At what point should this be trimmed flush ? The bottom panels stick out about a half inch from side panels in the stern. Should I do it before fillets or after ?
RE: Bottom panels stick out from side panels in stern on Chesapeake 17
Thanks for your response! Will do as you said. This is my first build and it seems to be going a lot easier than I thought it would be ! Loving it !
» Submitted by hspira - Sat, 5/8/21 » 2:15 AM
my preference is to do that sort of trimming before fillets....just so that i can ensure i have the wood meeting as tight as possible before the fillet goes in.
you may find after the trim that you can adjust the tension of the stitches a bit to close out any little opening the trimming exposes.
the bigger the gap, the more important it is to address it prior to filletting. but 1/2 inch is not a lot.
